None of us make the rules.so what about the EWR 1989 an HASAWA 1974,the testing procedure is there for a reason to protect the end user,installer and anyone else involved,this is non negotiable as far as im concerned,now if a gas installer fitted a heating system and didnt do a gas leak test before switch on and blew the street up what would happen,people going to court thats what,you are the installer you should be telling him the procedure and not the other way around.
Yeh maybe so BUT same with speeding, same with doing stuff not to the book all the time.. Like it matters!
people have sped, same thing there if they ran someone over they would go to court.. BUT YOU STILL DO IT
Like ive said before if you do everything by the book nothing will ever get done.. Do you wear goggles every time you drill.. Do you wear steel toe cap boots every day for work, do you drill and tie in your ladder to the wall when doing high works or get someone to foot it..... DO you check your drill EVERY DAY before you start work.. Do you check your VAN for safety every day before you work
and the list goes on.
End of day power on no one in house i know ive wired t good i do a tug test on every connection i do so as far as i see it theres nothing wrong with it.. If i did make a mistake and made a switch live woopy doo im the one who gets the shock
End of bored of your ignorance
Man your starting to REALLY BORE ME
Im in business with a mate, he has the NICEIC end of
It is against the law to use a LOGO without permission even if you pay for there service.. Reason NICEIC logo is not on my site is that reason exactly i have an email currently sent to NICEIC asking for permission, i also have one to C&G etc etc..
OH do you not email before you use logos on ur site and van.. Tut tut mr i do everything by the book has not done something by the book? Tut Tut
can't be bothered to read all the posts so you may of solved this before anyways! i would look at getting rid of all switches incorperate chock blocks or wagos upstairs and down if doesn't work check wirring dead resistance check make sure cable in switch is going back to light and not via distribution board via another circuit.
How exactly to you manage to come to the fact that i am ignorant?,you are being offered constructive advice by many members on the forum and are using some quite awful replies to people that have made an effort,but your replies have been shut up retard etc,the ignorance would in my opinion lie with you sir,good evening !!
WOW Frighteningly honest in-site into £££££ before your own safety...........what can i add?? ........just hope your right and the Tug Test keeps you safe fella :-/
tell you one thing i wouldn't be doing if i had failed to diagnose a simple fault, crying about it like you are. i hope loads of your customers and potential customers find this post!
next iwould put in gu10 bulb in or m16 in to check if the led you have needs total 230 v but i am gueesing now?
we are here to help guys remember? i have not dealt with the new fangled led light yet.if this was just About 2 way switching then i think he would of solved it by now.
saying that i have always been brought up on logic and therefore use it as much as possible,look at total problem then diagnose every possibility never mind how remote and tick off each.i was caught out the other day switch not working checked continuity from light switch to light,fine tried to conect new switch failure spent ages trying to work it out,my only solution was that the live into swich was from radial light circuit not going dirctly to switch, iam still trying to work out the settup?
Surly an R1 + R2 dead test would ensure thats its wired correctly. Providing the switches are correctly connected then polarity should be made and broken by each switch whilst testing at every light fitting regardless of what type it is. this should determine your fault. This should determine your fault, I find it bazzare that as its a new build you are trying finding your fault by energising the sytem.
i don't need advice though as i have quoted via my plasterer that i just feed from light fitting to new switch,the only problem i can see is my plasterer will probably do it himself .he has called me out 3 times this month to resolve cr&%p, next time he rings i want call out fee,he is a family member slightly
This forum goes from strength to strength 5 pages for a probably faulty light switch that could have been solved by a bit of testing.
With the number of faulty switches I've had recently it's an achievement to complete a job without at least one faulty switch
