L
LankyWill
Your degree is completely irrelevant, I think your over estimating your skill set. Not only are you putting your self at risk but also others that come into contact with your 'have a go' attitude.
Thanks for all the replies. It's quite funny and I appreciate the concern and advice.
It was meant to be a temporary solution put in by myself but then I didn't find a suitable box in Wickes or Screwfix that would accept the armoured cable.
It is some kind of old box that housed a switch, definitely not water tight.
I will try to find an IP65 box that can be drilled out to size.
I am not an electrician but I am doing a masters in Electronic Engineering, admittedly specialising in embedded software. I also have a copy of the 17th edition BSI Wiring Standards somewhere but I haven't really read it. I don't need an electrician, I just can't find a box. The wiring in the garage is much better! I have emergency stop buttons for the sockets, LED lighting, and a PIR for the lights.
give the poor boy some credit. in Lancashire it would be a choc block wrapped in a tesco carrier bag.Thanks for that mate. It's made my day. Couldn't stop laughing....![]()
... I don't need an electrician...
The problem I have is the junction outside the house where the 2.5mm meets the armoured cable, I can't find any glands or outdoor rated junction boxes to suit an armoured cable and 2.5mm.
I think your Problem is you've broken the Law.!
While BS7671 The electrical wiring regulations is a non statutory document, Part P of the building Regulation is a statutory requirement ! have you made notification to the local building control ?
Also were you planning on taking this dangerous installation out when you eventually sell the house or would you just leave it in for the next unsuspecting home owner?
Its is not safe and it could quite possibly be lethal, I really hope you don't have any small children running around the house.... no worth thinking about really.
Please get an electrician in to make it safe.
I know my degree isn't wholly relevant, I was just giving some background, I'm not a DIYer who's gone too far, I've designed, tested, and had approved circuitry for safety systems and modules used in building management systems for a multi national company...
Wow... Calm down guys, yes I sleep well at night because the box isn't live, I kill the supply when it's not in use as mentioned above. It was a temporary measure that I've only just got round to addressing.
I know my degree isn't wholly relevant, I was just giving some background, I'm not a DIYer who's gone too far, I've designed, tested, and had approved circuitry for safety systems and modules used in building management systems for a multi national company... With your recommendation I will find an appropriate box with glands and rectify the problem! I will take photos when I'm done.
As far as I know the council doesn't need to be notified because there was an existing garage with power, (you guys would've freaked out if you saw the wiring for that, but no photos sadly!).
Once the box is fitted it will be a massive improvement on what was already in place.
