Discuss Pipe and cable detector in the Electrical Tools and Products area at ElectriciansForums.net
Evening all, what do you good people use to detect hidden cables and pipes in walls my Bosch scanner is unreliable and triggers if there are no cables present.
Pipe and cable detector {filename} | ElectriciansForums.net
these my detector .
Look down to your feet and see if there’s any sockets down there. As for gas pipes a general look around as to where the incomer and services are is normally a good start.
Been lucky so far.
I'm afraid the simple detectors are a bit, well, simple. I bought one a while back and tried to find metal capping in about 10mm of plaster with live cables chased in behind it... Maybe the expensive ones are better (?).
As Wilko said. I had the Bosch green one. Has a 1 in 10 chance of locating a pipe/cable, or it indicates after turning it on when somewhere near or close to a surface.
Perhaps the more expensive ones are better :confused:
i have a bosch one. it's pretty fair accurate, tends to err on the side of caution. once found a metal washer that had been plastered in about 70 years ago.
Have a Bosch one , and has been said not a lot of use ,cant trust it. Have a couple of powerful magnets for finding studs
Cable construction, directly buried cable when the best and joint. The joint is protective, but it's not strong. The joint of conduit cable is chosen commonly in the position is better, do not have how much water, good secure and convenient the pipeline that look inside. Aerial cable joints are generally selected in the vicinity of the poles, so that it is convenient to view later, maintenance. And fixed.
:smile::smile:
:smile::smile:
:laughing::laughing::laughing: One more than you, thought it was worth it
Reply to Pipe and cable detector in the Electrical Tools and Products area at ElectriciansForums.net
