Discuss Pir wall lantern with manual override function in the Electrical Tools and Products area at ElectriciansForums.net
I would suggest reading the installation instructions for the lights to determine if they have an internal manual override or fit a separate PIR sensor with an external manual override switch.
A lot of the descriptions state with manual override so a search for "PIR Wall lantern manual override" should get you some results.
I'd already been scouring installation instructions but hadn't had much luck. I want one with an internal manual override because the customer doesn't want a separate sensor. I'd already tried almost those exact words but in a different order and hadn't had a lot of luck, but have now tried those exact words and found a couple more options, so thanks.
most units have the feature that if you flick the switch off/on twice within a few seconds, they come on manually. then switch off/on with a gap of 30 seconds they revert to PIR operation. check out Timeguard PIR floods ( halogen or LED). These also can be wired in 3core/E so the 3rd core is for manual switching.
Reply to Pir wall lantern with manual override function in the Electrical Tools and Products area at ElectriciansForums.net
Looking to fit a USB-C PD wall socket for charging / using a laptop - so I was hoping to find one that supported 90W or higher charging, though...
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
Driven by the recent colossal hikes in the cost of electricity I hit upon the wizard wheeze of replacing some of the existing LED bulbs in our own...
Ok so I have a quinetic switch connected to a relay which turns it into a 2way switch.. I want one output going directly to the lights and the...
