Discuss Plastic bayonet light fixture melted. What's the problem? in the Industrial Electricians' Talk area at ElectriciansForums.net
K
Kingbroady
My landing-light bayonet's plastic housing has melted. Naturally it needs replacing but I would like to know what may have caused it and what should be done, please? ie Too much voltage etc?
Any help is appreciated.
Thanks.
You need to check that the rating of the lamp (bulb) is not too high for the plastic. Also check the terminations inside and ensure that you have no 'arcing'. Assuming you are not a spark then maybe get one in to check all is safe and sound.
As Cirrus said check the connections as could be loose connection causing termination to overheat.
As above.
I had similiar problem a couple of week ago. Sheathing had gone on the Live.
Trimmed down and replaced.
(After isolating)
Could be loose connections on the terminations causing it to heat up, I had the same problem on a socket outlet, it was getting warm and my tutor at college just said to tighten up my L N & CPC.
mostly find that the plastic is heated over a period of time and becomes brittle normally from a 100w lamp. best solution is to use a 40/60w lamp and replace the lampholder and flex to the rose, some newer ones are 150w rated
Reply to Plastic bayonet light fixture melted. What's the problem? in the Industrial Electricians' Talk area at ElectriciansForums.net
Hello, as a relatively newly qualified electrician (mature trainee who completed his NVQ in 2023) today was the first time I've seen a melted...
Info: Located in US I have a 48” T8 fixture that I recently added LED’s by removing the ballast and wiring directly. After doing so when hanging...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
Hi All, Please may I ask if light fixtures must now always be fitted by an electrician? also for domestic homes, is it okay for there to be a...
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
