Discuss plastic conduit in the Australia area at ElectriciansForums.net
A lot of people use plastic conduit outside nowadays more for protection than waterproofing as the cables inside should already be waterproof, it helps against small knocks (metal conduit if a hight change of damage).
A lot of shops who have exterior lights fitted but don't want the internal walls damaged on installation opt for conduit as installed correctly, can look professional (much better than clipped cables) and protectes the cable against UV & Weather decay.
Remember when joining lengths of conduit outside that hot & cold weather can shrink/expand the conduit so allow expansion joints to prevent this.
As eskimo has said about helping with small knocks
There are 2 types of PVC conduit LG - Light Gauge and HG - Heavy Gauge which has thicker walls and can take a lot harder knocks than LG
Rather than worrying about keeping the water out i would make sure there are a couple of drilled drain holes at any obvious low points to allow any moisture/condensation to get out .
edit ; If you are going to need drain holes put them in before you put the cables in so you don't drill the cable ;-)
Drain holes defo the way to go
Reply to plastic conduit in the Australia area at ElectriciansForums.net
Doing some work in a commercial restaurant/kitchen the builders had already boarded and plastered the walls meaning my only viable route is to use...
Hi everyone, I intend to bury a 240 volt cable from my house to my barn about 7 metres as way. It will be buried under my tarmaced drive which I...
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
Hello, I have 50 ft of corrugated pipe buried between my house and a pool shed. I placed it where I knew future landscaping would make it very...
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
