Discuss plastic throughout the building in the Industrial Electricians' Talk area at ElectriciansForums.net
V
vectraj
so i have plastic pipework through the whole house (domestic) even coming right out the consumer side of the stop tap,the only thing that isnt plastic is the 22mm gas main which is earthed 10mm. now am i right in thinking all i have to x bond is @ the boiler...? ie gas-flow-cold-hot-return. i have earthed the supply side of the water main 10mm which was in 15mm copper. what about the metal sink in the kitchen?:confused:
Reply to plastic throughout the building in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
What are the regulations requirements on Earth bonding ? I am currently planning a 1st fix re wire I have the following setup Gas Meter...
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
Please can someone explain if this is a TNCS or a TNS earthing arrangement because it looks like both to me. Old undersized main bonding conductor...
