Hi all,
Thought id ask on here first if its allowed, before having to register on a plumbing forum.
I have got a problem with my toilet at the moment, everytime I flush it, it makes a horrendous loud noise which sounds like the fog horn on a ship !!!
Do any of you know what might be causing this, and how to rectify it ?? I wondered if it might be an air lock or something. Any advice would be much appreciated, if you have ever come accross this before.
Thanks in advance
Darren
inside the ball valve is a rubber gasket. it will be that they go hard after a while. 5 min job to change and usually no tools required.
Gary:D
Hi Jason
Need a bit more info eg has it just started has anyone done any plumbing work etc.
it sounds like water hammer, which as the other guys have said it could be a perished diaphram washer or it could be that the water pipies need better suport.
Steve
pfft if your all that good.........
i put a new pressure release valve on my combi and changed the expansion vessel as the pressure wouldnt hold (valve was dripping + us, vessel wouldnt hold pressure)
ive tested everything else
and now my pressure just keeps going up?
worcester 24i combi
cheers mate :)
worcester 24i combi
cheers mate :)
Did you check the expansion vessels pressure before installation it should have 0.5 - 1 bar pressure before installation on the air side of the vessel
Your problem sounds like this was not checked
Just replaced 2 recently with no problems
You would need to drain some of the water from the system to release the water pressure in the expansion vessel you can then check the pressure on the air valve with a car pressure gauge
Plumbing question if its allowed ???
Australia
Dazza1976,
Dazza1976,
