Discuss Possible fire risk? methinks in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
looks like a prototype for line products "eggs",
Could I put wagos in one of them? Would it be classed as MF? :)
Well...the cables have strain relief:D
But Wagos are only certified as MF compliant, if they are in a Wago enclosure.
Extract from Wago website
It’s important to note that the connectors and the enclosure do not qualify on their own as maintenance-free accessories. This is because an accessory is defined as the whole equipment and may comprise of two separate products – the connectors and the enclosure – both have to be certified for use together and installed according to the manufacturer’s instructions.
That is just a technicality:mad:
Reply to Possible fire risk? methinks in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell. There are call points, smoke heads &...
Good evening! Don’t have a huge deal of experience with fire alarms but having to work on a conventional system at the minute with various...
I'm about to order this wired smoke alarm system as it can network but I just went to see how my existing fire alarms are hooked up and there...
I'm about to start first fixing this fire alarm in the industrial unit we are wiring, at the moment its totally empty and eventually will have a...
Hi All, Please may I ask if light fixtures must now always be fitted by an electrician? also for domestic homes, is it okay for there to be a...
