Sorry, thought there were 2 batteries. Yes, you are right - it's 4.5VDC you need.Also the current of each light...would that be 1.5v X 3= 4.5v would the 3VDC be sufficient
Perhaps something like the attached and solder the three sets of wires (after removing the battery packs) into the line there ?Sorry, thought there were 2 batteries. Yes, you are right - it's 4.5VDC you need.
The current needed depends on how much the lights draw. It will be very little, and I would say if you get a 1 Amp power supply that would be more than enough.
You can join the wires either in the DC socket, or splice together separately. It's not critical to be honest. Ensure they are all wired in parallel though, ie. all positive wires together and all negative wires together.
