J.C.E
New kitchen extension in surrey- assume white plastic sockets
Consumer Unit
Assume existing BG dual RCD consumer unit can be utilised (spare ways)
Assume mains earth bonding to gas and water are present and satisfactory
Assume mains powered smoke detectors are already installed on ground hall and 1st floor landing (interlinked)
Lighting Control
Supply and fit 1x Lutron Grafik Eye panel 3 zones in white finish by entrance into kitchen (QSGRK-3PCE-WH)
Supply and fit 1x 2nd switch in white finish at opposite end of kitchen (QSWE-5BRLN-AW)
Lighting
Supply and fit 6x fixed LED fire rated downlights in white finish
Supply 3x feeds for 3x hanging pendants over island- client to supply pendant fittings
Supply 2x feeds for 2x wall lights- client to supply wall light fittings
Supply 3x feeds for 3x outside wall light + 1x 1gang 1way light switch inside door- client to supply lights
Power
Supply and fit 4x d.sockets (not USB) -general use
Appliances
1x independent 40amp cooker circuit with isolator switch
1x independent 40amp hob circuit with isolator switch
1x single socket for extractor hood- with isolation switch- builder to provide core hole and ducting
1x under worktop single socket for dishwasher- with isolation switch
1x under worktop single socket for boiling water- with isolation switch
1x single socket for fridge/freezer
Cooker/hob switch isolators -to be located/hidden in wall unit- white plastic
Grid switch controlling appliances
Other
1x 13amp switch fuse spur for UFH manifold- spur only (not including any control wiring etc)
1x 13amp switch fuse spur for boiler- spur only (not including any control wiring etc)
1x mains powered heat detector- to be interlinked with existing smoke detectors in house
TOTAL
No VAT to be added
£2,419.80
Bump. I'd say a bit cheap, but probably a bit late now.
it was just the lutron part I was not sure on as not installed lutron before.
I was quoted £785 for:
1x Lutron Grafik Eye panel 3 zones in white finish (QSGRK-3PCE-WH)
1x 2nd switch in white finish (QSWE-5BRLN-AW)
and wiring appears to be no more trickier than it would be in 1.5 and 3core for a 2way switch
-I did base my quote on using cat5/6 between the main panel and the 2nd pad- but 25m of the proper lutron cable was only around 60quid odd I think
