Discuss Proving Unit for assessment in the Business Related area at ElectriciansForums.net
S
se7aq
Ay up each...I have my Elecsa assessment coming up and my proving unit has gone astray...do I need to replace it to pass my assessment...?
Cheers
Hi mate, I had my ELECSA assessment in June, do not own a proving unit and was never asked to see one, so long as you prove on a known live source, aka safe isolation procedure.
No. Never owned a proving unit and have had a few elecsa assessments. You just need to show that you can demonstrate safe working. You can use any known voltage source before and after proving. For example a nearby socket with test lead adapter in place, or main switch input terminals if at the CU. Some may wish to argue about this but my assessor has no problem with it. Don't forget though that if you are working on a circuit you need to ensure that both live conductors are isolated - ie line and neutral - to avoid the risk of any other circuit with shared neutral being energised and under load.
Reply to Proving Unit for assessment in the Business Related area at ElectriciansForums.net
i need to purchase a voltage proving unit - i have seen Megger MPU690, Martindale PD690, and Socket and See SP400, and Fluke but difficult to...
i have faild napit annual assessment with silly mistake of using on consumer unit type AC rcd instead of Type A rcd. i bought type A rcd but they...
I’ve recently come into a people’s with my fluke T130 I’ve been proving it recently on my fluke proving unit and it shows 60v then ramps up to 90v...
Can I have a napit assessment with only on CU change? Really struggling to find work to be assessed as only just starting up with my company...
Hi all, Is there companies or people out there that can help source sub contract work as im not sure where to start. I know you get recruitment...
