Nothing to do with h&s, You have to be authorised to work on dno's cutout by holding a MOCOPA certificate which is renewable every 3years.It is the dno's equipment solely,and it is only them who can withdraw the main fuse and reinstate weather sealed or unsealed end of.
Last thing you would want to use, some of those kitchen gloves are known to be semi-conductive!!!
You're talking out of your rear end. Yes you are correct that you need to have authorisation to work on their equipment and/or make alterations to their equipment as it is their property, this is even mentioned in the ESQCRs however removing a fuse is not working on their equipment nor is it altering it!!
Shame, I guess from now on all firemen have got to hold cocopops certification to pull main fuses too, if they don't they've just got to watch the property set alight and burn to the ground![]()
Not once in this thread have I heard of a "Pair of Marigolds" mentioned![]()
The SSE recently told me it ws fine to cut the seal, as I'm NICEIC registered
