On point A) though with 2.3 ohms being a 100 amp fault current which depending on the type of breaker B,C,D and current carrying capacity of the rcbo then hoping that 100amps is enough to cause a thermal cutout due to excessive heat, and a 100amp fault current is more than enough for an unbalanced magnetic force also tripping it out? Would it be due to thermal cut out and not from RCD
I've got a test and one of the key questions on it is as follows;
230v Single Phase Circuit is protected by a circuit breaker with integral RCD(RCBO), Justify which competent part of the device would operate for each of the following faults:
A) Line to Earth Fault of approx. 2.3 Ω
B) Line to Neutral Fault of approx. 0.01 Ω
C) Neutral to Earth Fault of negligee impedance
D) An overload of approx. twice the nominal rating of the device
Help would greatly appreciated as test is tomorrow at 4
basic stuff kid...
if you had done the research....then you wouldn`t be asking such piffle in here...
oh, by the way...best of luck tomorrow in the exam...
100A fault current would trip an MCB on thermal trip within about 5 -1000 seconds depending on rating and type.
100A current flowing to earth would be a major excess over a 30mA current and the RCD would trip in say about 20 milliseconds.
Therefore which will go first!!
Eh !!!
Thought you said you were learning?
edit...............
Just saw Richards post lol.
Lead a horse to water and all that...................geez
This spring to mind..
