H
Discuss rate my fuse box (or consumer unit to be politically correct!) in the Electrical Forum area at ElectriciansForums.net
The original fuseboards were in the cupboard beside the meter as in the picture. The cables ran behind the bit above which was already boxed in with plywood. All I did was move the new consumer unit up and replaced the plywood. I upgraded the tails to 25mm and took them up to the new position. Do you think I should have an upfront 100mA rcd?
Reply to rate my fuse box (or consumer unit to be politically correct!) in the Electrical Forum area at ElectriciansForums.net
