It's on all sockets. I'm testing from the board
No, i mean is it when there is a load on one particular socket? Did you you check your neutrals at the board? Have you tried a drifferent appliance in case the one you are using is causing the tripping (that's if you havent PAT tested it)?
ive managed to find the problem. one of the back boxes (not mine) was causing an earth fault. there s a bit of old cable cut out and terminated behind the back box. removed it and now my ir is spot on. internet is really slow takes ages for the page to refresh.
