A
Andy78
If it really is for a specific item then chop the plug off and connect it into a FCU
What is dumb regarding the above disagree maybe please explain.Back to the thread ..I the socket was behind the item of equipment and not readily accessible label it. If there is a likelihood that it could get used then fit a rcd socket as said risk assessment.
i wondered that.What is dumb regarding the above disagree maybe please explain.
Agree I've had a fewI have noticed a lot of the "dumb" posts and the like come from the ghost watchers.
The only thing that is dumb is the choice to press the dumb buttonWhat is dumb regarding the above disagree maybe please explain.
Agreed I did complain about this initially but it fell on deaf ears.Shouldn't be a dumb button.
...... chop the plug off and connect it into a FCU![]()
Yes as your installing a socket outlet with rcd protection.just a 'technicality' query - the regs are not retrospective, so the existing circuit
(assuming it was installed pre RCD days) does not have to be RCD'd. Would fitting
an RCD socket therefore comply with current regs? ( Just curious! ).
