Discuss Replacement required, heating controller 40A Supply, it operates ceiling heaters above the plaster in the UK Electrical Forum area at ElectriciansForums.net
Ceiling heating was a terrible idea thank god it never caught on.
Absolutely ridicules completely agree, never seen this before but the controller/ timer has failed and requires replacing but I'm not sure if there's anything on the market that I could replace it with, it's supplied by a 40 Amp mcb and the timer would need to take that load. I'm not sure of the current draw of the individual ceiling heaters although there's 4 x 15 Amp breakers and 2 x 30 Amp, what would you suggest?
Reply to Replacement required, heating controller 40A Supply, it operates ceiling heaters above the plaster in the UK Electrical Forum area at ElectriciansForums.net
Wonder if anyone can help out, my experience in heating is minimal. So house I was working in had a circuit for the water heater, which went to a...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hi There Just a quick one, I'm wondering what's everyone's thoughts on this are. A subby has clipped a cable to a plaster board ceiling using 3m...
Looking for counsel / guidance to replace an original Dayton On/off with speed control switch. I’ve checked with a couple local electrical supply...
How would you go about this realistically, the office is open plan and about 15m x 7M, grid ceiling with loft space above, windows and insulation...
