Hi
I could do with some advice/opinions on how to tackle changing 2 gang switch for a 1 gang switch
Basically the Kitchen has two lights on either end wired in a loop
circuit. Currently there is 2 gang switch working the two lights (not wired as a 2 way switch). Thus when you open the switch box you have 2 live wires etc, running out to each light etc.
I don't need a two way switch and want put both lights on one switch. Is it case of fitting a 1 gang switch and putting both feeds into the switch?, or is there a better way.
Please note that to wire the two lights together, I would have drill every ceiling joist due to the way they run across the kitchen
I appreciate this is a professional forum and I am not, however my electrician who checks the work is off two weeks, and I do really need to get things sorted.
Regards
Ben
Regards
Ben
