Please come check out EFbot; Testing thread is here. Come see what it can do. . Tag it in any thread using @efbot you will need give it a few seconds and refresh a page for it to post a reply post.
Called to a ring main fault. Customer has had some work done about 3/4 months ago. Have not yet found the fault but noticed on inspection 3 of these ring main extensions. What do you think. 15amp thru crimps!!
Better than chock blocks! As per previous post I've always thought (and been taught) they were ok on ring mains but I don't use them unless enclosed in trunking or box etc, in this case a MF JB would have been more acceptable. Can't beat em for extending cables on a con unit change.
Gota say them joints are good compared to things , we no doupt have seen before. ok it now means the drops run outside the prescribed zone, but in the real world small things like this are sometimes done, would be nice to have seen them covered, but at least its not just choc blocks or worst just twisted and covered in tape.... I bet you havent found the fault yet and are saying its because of this bad install.
edit.. sorry you say ring main fault. what kind of fault are you trying to find?
you could quote to rip the floor up and rewire the legs back and then re run in prescribed zones with no joint...
