so i have been given this diagram and no explanation on what nay of it does, its for a safety relay for a robot cell it says this:
'Safety relays can made up of 3 relays (CR1-3) to ensure redundancy and cross monitoring, and can be applied to the following applications: ■ Emergency Stops ■ Light Curtains ■ Three Position Devices ■ Interlocked Gates/Hatches ■ Magnetic Switches ■ Light Beams ■ Safety Mats ■ Contact Strips ■ Foot-Operated Switches'
I'm assuming that the CR = is a relay safety device like a light beam?
I'm not to sure what '=/' is suppose mean, its never been explained to me. I assumed that when power goes threw it disconnects stops power to that relay?
I don't know what the squares mean before pretty much everything with 'A1X' 'A1Y' and so on I'm assuming that its nothing and just a way to identify things but i could be wrong.
So this is how I'm currently reading the circuit:
When start button is pressed CR1/2/3 activate and power up. I'm going to assume CR1 is a light sensor which when the beam is broken the machine stops, I'm going to assume CR2 is a magnetic switch on the door; when open breaks the circuit and stops the machine and then CR3 is a interlocked gate what will only open when there is no power to the machine. When the start/reset button is pressed it resets CR1/2 but CR3 stays active because its needed to so that entry can't be obtained whilst this happens (I'm reading this from the reset/start line on the circuit). When the emergency stop button is pressed this will disconnect CR3 allowing access to the area. whilst someone is inside power wont be able to come back on because of CR1 light sensor which will be detecting if anyone is in the area. If I'm right on how this works then i don't understand CR3 '=/'. I doubt that I am right though because this is just a bit of a guess.
If anyone could help my understand this I'd be really grateful, thanks in advance.
