Afternoon all, need a bit of advice. I live in a flat in a building which has been divided up into 6 flats, next door is a similar building of 6 flats, both buildings are owned by the same management company. When we get our service charge each year, we have noticed that it says "Landlord supply of electricity for 5 and 7 = £xxxxx /2" so the charge for communal lighting is split with next door. We always thought this to be curious until we had an electrician come and do some work in our electricity cupboard.
He pointed out there was a cable running from our communal supply meter, down through the floorboards. he also noticed that the isolation switches were doubled up, ie 2 switches for lights, 2 for sockets. Only one of these switches affected our lights or sockets. We called the supplier and they confirmed that there was no landlords supply for 7 (we are 5) We knocked at 7 and they told us they had no meters for landlords supply, only their own meters for th individual flats, as do we.
So my question is: Is this legal?
Sounds like the flats were originally all rented out, and the communal lighting split among all renters.
As flats were sold off, no one thought to question this and it’s remained.
It’s something the original buyers solicitor (and every subsequent solicitor) should have picked up on. Although if everyone pays the same, there shouldn’t be a problem.
how much does it come to for each flat? Can’t be much.
Thanks for the reply. Well we are paying, on average, £105 per month for intermittant communal lighting and sockets which are only used when the caretaker plugs in the hoover. This is around 4 times what a two bedroom flat uses in a month. I understand there is something called a looped supply, but there should be a meter in the other property.
Ouch. Is that 105 each?
that’s ridiculous for a few lights.
It doesn’t matter how it’s metered if the understanding is that it’s shared equally among all residents in both blocks.
I wonder if someone has tapped off the communal supply for their own use....
maybe you need to contact the management co. of the other block. There must be a way to reduce that.... LED lamps or sensor type lights that only work when someone is in the stairwell.
Thanks once again, yes £105 per flat. An issue is that next year we are going to apply for a Right To Manage which we will be unable to do if the other property shares a supply with us. I thought each property had to have its own meters and RCD switches for safety?
Is this £105 per flat the actual amount paid to the electric supplier, or is the landlord adding some "'mark-up" of their own?
If you are not sure, you could make monthly readings if you have access to the meter, and check if the amount billed anyway tallies with the usage recorded by the meter.
Thanks SJD, The bills do tally with the Electricity bills, so there is not much doubt it is what the two buildings are using. As soon as we get our Right to Manage we can go for LED lighting etc, but right now, we have no control over what next door is actually using.
i would take it up with the management company telling them that they are stealing electric from you and the other person ,and ask them to see the covermount of the building in which the building stands on ,and go from there .i also do litigation in my spare time like taking down the bad boys .lol.
The Management company are not on site, these are two 1900 buildings which share a management company. The cost of electricity is caused by inefficient lighting which we cannot resolve until we take over management of our building, No 5. We cannot take over the running of our building until we have our own utility supply.
Is that £105 p.m divided over the 12 flats or £105 each flat?
Electricity cannot be resold at a higher price than paid, so whatever the Management are charging has to match the cost they pay.
The (minor) issue is going to be the fact no.5 has the only Landlords metered supply so when no.5 takes over the management a new Landlords supply will have to arranged for no.7.
The cost will have to be negotiated as to whether no.7 Landlord pays or the costs be split between the 2.
This all seems a bit odd.
If you switch off the fuse board connected to the landlord supply do the lights go off in number 7?
Request a copy of the bill for this supply from the management company, check that this is based on actual meter readings and not estimated. Also check that the management company have not added any markup to the bill, this would be illegal.
I would switch the LL cu/switch gear off and see what communal circuits go off, and if any are still on, then do the same for each flat at the origin one by one to prove who is paying for what.
Liverpool
United Kingdom
Shared mains supply
UK
Seventies1,
Seventies1,
