Discuss Single Gange Outlet + Dimmer Switch in the UK Electrical Forum area at ElectriciansForums.net
ksdennis
I am looking for a single gang outlet + dimmer switch combination.
Does such an item exist?
It's for a kitchen backsplash the outlet would be unswitched and the dimmer/switch would control a light over the sink.
The whole backsplash is on a GFI so I don't need a GFI in this device.
-Kevin
-Kevin
A single gang box won’t work, it sounds like you need a 2 gang box for the dimmer and receptacle and if it is already GFCI PROTECTED the you can add a regular receptacle but you need to install a sticker saying GFCI protected
Reply to Single Gange Outlet + Dimmer Switch in the UK Electrical Forum area at ElectriciansForums.net
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
My daughter is asking me if it’s possible to change her double light switch outside her bathroom to a dimmer. It’s a 2 gang switch that turns on...
DYI guy here with some basic knowledge of electrical craft. I am helping a buddy in his remodeled bathroom. His GFCI outlet was powered off vanity...
Hi all, I am upgrading my traditional 2 gang light switch in the kitchen to a smart 2 gang dimmer switch. When I wired up the switch the switch...
