N
Noob2013
Hi all,
Just curious;
I know the general height of a socket is 450mm to bottom but if it was lower (say 300 mm to bottom) would this be picked up by building control in a new extension (not new build) or is it just a case of using common sense providing appliances can be plugged in safely without bending the cord?
Cheers
Well, if it was just one socket in a position for a certain use because it was not possible to put it elsewhere it should be fine, in the same sense you could put a socket high up behind a wall mounted TV.
It would be up to you and the customer to talk with the BC officer and agree a suitable height for the sockets. Some of them are quite reasonable people. Above 450mm is a recommendation only as one way to comply with building regs.
Ok but as an example;
Electrician runs cables, carpenter plasterboards and cuts holes for sockets (300mm to bottom), painted and decorated, electrician comes back to fit boxes and connect sockets....
Would building control really expect them to make good the holes they cut and re cut at 450mm to bottom?
Seems extreme for the sake of 150mm in an extension. I could understand in a new build.
Just in the process of doing an extension myself, no way will my customer want his new SSO at 450 when his existing ones are at 300. New build is a different thing altogether.
We made cock up on a job 450mm to top of box,really picky site,we didn't say a word,no one noticed on completion,the site agent wa a real knob,would of loved to have told him he missed something,but never did cause of all the hassle it would of caused us ,ha ha
As already mentioned, 450mm normally doesn't apply to extensions, and if in doubt about anything, talk to the BC officer. I did the electrics for an extension the size of a typical 3-bedroom semi last year, some things BC were concerned about (positioning of smoke & heat alarms was one), some things were not required (socket & switch height was one, they were put low & high to match rest of the house). And some things were negotiable, like a missing extractor fan in the utility, BC accepted the huge cat flap in the wall would do instead!
Socket Height?
Noob2013,
telectrix,
