Discuss Solar inverter showing low dc input ( with pictures ) help please in the UK Electrical Forum area at ElectriciansForums.net
Cs111
hi everyone, hopefully you can help.
I have a 4kw solar panel system and just noticed a drop in how many kw it’s producing. I checked the inverter ( fronius primo ) and the lcd is showing low dc input on string 1.
Any ideas of what the problem could be ?
Even if I could narrow it down to what I should be checking
On the lcd
Is as follows
I checked this morning around 9am and had the same problem as Friday, basically only one string of 2 is working hence only getting 50% input compared to normal.
One reason could be the gradual reduction in panel power output as the panel rises in temperature, which might be particularly troublesome for you if the panel is on your roof and our sunny weather and blue skies bathe your panels in high intensity light for long periods.
Are the panels side by side such that is no geometric reason why one should be hotter than the other or is there some significant difference in spatial location and orientation between the panels which would result in one becoming noticeably hotter than the other?
See:
Solar Panel Temperature | Effect on performance - https://solarcalculator.com.au/solar-panel-temperature/
Yea 12 panels on the roof, all side by side.
I tried contacting the installer yesterday on 2 different numbers but the lines were dead and website down, though companies house have them as still active. Don’t think il get anywhere with them.
Just thought if there was something obvious that I could try I would.
Output may come back up as heatwave passes, if you are lucky and your panels are good quality. Else someone will have to go up there and check the individual panels, change out the bad ones. 6 Panel string likely deliver around 200V DC. Don't mess with them unless your familiar with working on electrical systems.
Suspect a panel on that string has failed. Get someone in to check outputs and bypass faulty panel so as to get that string up and running. Long term, find suitable replacement panel
Reply to Solar inverter showing low dc input ( with pictures ) help please in the UK Electrical Forum area at ElectriciansForums.net
Hi all. We have had 7x 400w solar panels for a number of years now on our roof which is se/nw facing end terrace. 4 on se side 3 on nw side...
Hello Our 4kW solar system generated 4.4kWh today (Sunday 13/03/23) compared with our neighbour’s 6.4kW system which generated 19kWh. Clearly...
V.early days, just had installed solar. No battery, also supply of some parts difficult at the moment so no App or Online monitoring. I have a...
Hi all, I hope you can help me please. I had solar system installed nearly 2 months ago and my installer turned out to be cowboy despite having...
5K
I'm hoping someone out there has come across this problem. Just had -8 days ago- a 6k solar panel system plus 4.8k battery pack installed. When...
9K
