G
gordysolar
hi id like bit of help if anyone can help me this is my first post i have my mcs assesssment on the 1st november have doen a 2 panel install on my garage 2x sharp nu 245w schuco mounting system with a soladin 600 inverter
when doing insulation testing on panels do i megger it with panels connected + to earth and - to earth ? and on 250volts
also my generation meter is fitted before ac isolator in garage as my nic training notes show. Can the meter go between the ac isolator and inverter ?
whats easiiest tool to use to get the solar shading ?
And finally when measuring the temp for test conditions do i measure air temp or panel temp with my thermometer?
