happysteve
Broke Internet
Supporter
If you just want to use the PDF forms - MEIWC, EIC, EICR, test sheets - then please download the files from this thread:
This thread is for those who want to try tinkering with the original source files, the libreoffice files that I use to generate the PDF forms.
I can't upload the libreoffice files directly (they have a .odt extension) as the forum, sensibly(?), does not allow this file type.
I have managed, however, to export the source files (individually), as PDFs with embedded .odt files in them. This means that if you open one of these PDFs with libreoffice, you should be able to tinker with the forms... add or remove fields, fix typos, add your own company logo etc.
This is not for the faint-hearted.
I will not be offering technical support.
Happy to give some tips, though...
- For historical and memory-management reasons, the EIC and EICR (and test_sheets) final forms are each made up of several source files, as follows:
EIC: EIC_form + circuit_details + test_results + EIC_notes
EICR: EICR_form + inspection_schedule_for_EICR + circuit_details + test_results + EICR_notes
test_sheets: circuit_details + test_results
(MEIWC is just MEIWC_extended, the notes are included)
Once you've finished tinkering with whatever part of the form you're working on in libreoffice, you need to export it as a PDF.
- Select File, then Export as then Export as PDF.... (do not be tempted to use "Export Directly as PDF")
- Here are the options I use to export to the PDF forms I uploaded to the forum:
- If you want to export it with an embedded ODF file (like these source files are), then click "Hybrid PDF (embed ODF file)" in the top right.
- I have tried more modern PDF standards from the dropdown list top right, but this always ends up messing up the tab order. I don't know why. As far as I can tell, no-one knows why. If you select one of the lower options, then you cannot unselect "Tagged PDF (add document structure)", and it's this option that seems to mess up the tab order
- Once you have exported the PDF from each source files, you need to find some way of joining them all together. I use a cheap (pay once) app on the Mac called "PDF Splitter + PDF Merge" - I'm aware Preview (the built-in Mac PDF viewer) will trivially joint PDFs together, but I don't trust it to not mess up the PDF forms. I'm 100% confident there will be a trivial command line tool to do this on linux (I used to use pdftk)... Windows, I have no idea, sorry.
- Once you've got your combined PDF form, use it for jobs etc (or upload to the forum if you think it's an improvement on mine!)
Don't sell or monetise these, don't offer AI enhanced versions, don't contribute to the death of the internet and all things good in the world. Just... tinker, and enjoy! :)
Here are the actual forms:
