Hi Guys,
Looking for some options to provide surge protection to a 100a TPN sub main to be wired 60m from the origin
Im currently looking at installing a 4 way TPN mccb panel board with spd at the origin but it looks as if its going to cost the best part of a grand
This is obviously a far greater cost than installing a TPN 100a switch fuse but don’t really see many alternatives
Any one any ideas to keep the cost down?
Is there already some board at the source?
If it is simply a sub-main from supply point to the existing DB then just put in a switch-fuse for cable fault protection (assuming not TT!) at the source and then have the SPD at the end DB.
MCCB panels are expensive, and unless you get the fancy and expensive electronic MCCB (maybe with EL trip) they have a lower and harder to meet Zs requirement compared to the good old fuse.
If you absolutely have to have the SPD at the source then you could use a switch-fuse for the 100A over-current protection and then have a small DIN box for the SPD and a few Henley block to join it up, or some DIN terminals that can accept the size of incoming and outgoing wires as well as the link to SPD, or some line-taps in the DIN box, etc. Just keep the cables from block to SPD short (less then 25cm).
Scotland
United Kingdom
SPD for TPN 100a sub mains
sparky1888,
pc1966,
