Discuss Spd from main switch in the UK Electrical Forum area at ElectriciansForums.net
Hello all,
i am fitting an Spd to an existing installation and looking through installation instructions and it has a diagram where the feed for an Spd located externally has come from the bottom of the main switch. Does not seem right to me. Just wondered what people’s thought were on this. I will try and post diagram
Hello all,
For an external spd
Thanks for the reply’s. It makes sense to me if it is situated next to main switch as you can fit a nice bus bar link. But if situated externally it would have to be a short length of 6mm .
Reply to Spd from main switch in the UK Electrical Forum area at ElectriciansForums.net
Has anyone fitted an SPD to a schneider standalone AFDD DB. Isobar P B Standalone Active distribution board, Acti9, 24 AFDD ways This board only...
Now that SPD's must be fitted regardless, how does this stand from a sub-main perspective? Went to look at a job and they want a supply to a pre...
Hi all! Does an SPD have to go at the front end next to the main switch or can it be fitted with its MCB at the end of the row of MCBS on an...
