Discuss "Spider light" installation.Domestic in the Lighting Forum area at ElectriciansForums.net
daveelectrician
IMG_0071.JPG Hi.
Just wondered if anyone has any experience installing a spider lamp in a domestic premises?
First time I have came across one of these fittings, it has a single rose with nine separate 0.5mm flexes, max 40w lamp. Just wondered what the correct way is to connect all the cables together. I wasn't comfortable connecting all nine lives and nine neutrals together in a single connector block( due to heat off 360w ), so I connected all nine flexes separately in nine connector blocks and looped the incoming neutral and lives. I have been asked to install more in the property, but it is difficult to fit 18 connector blocks in the rose. Ps a junction box cannot be installed as concrete ceiling.
you should not get heat at the rose. the only place you'll get heat is at the lamp holders.
I'll be honest, that anyone who thinks ramming that amount of connectors no matter what type they are into that rose is a good idea.
they'll all fit easily into wire nuts.
View attachment 33794 Hi.
I really dig that light!
had similiar one, took it home and dropped on a bench, soldered the lot leaving a length of 1.5mm wire for connection. insulated with heatshrink and rubber tape. load it up with led bulbs they will be around 5 watt each...
may be a good idea to DIY one from a big wagobox, some brass pendants and rubber silicone flex. that may go well in those trendy new hip places, lots of light and easy to install too.
Thanks for all of your replies, I like the idea of soldering, open to more ideas. This is like an IKEA special, which I expected to be already pre joined.
No one thinks of the poor sod who has to dust these things! That's not me by the way, I'm just speaking up for the little person! (Not being un-PC either)
Reply to "Spider light" installation.Domestic in the Lighting Forum area at ElectriciansForums.net
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hello, Looking for DIY electrical advice. I have 7 x spots, and each are fitted with 1 x T&E connector block fitting [see photo]. In the past...
Hi, asking for a friend in Australia. She wants to install two Pendant lights over a kitchen island and four downlights all on the same switch...
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
