daveelectrician
IMG_0071.JPG Hi.
Just wondered if anyone has any experience installing a spider lamp in a domestic premises?
First time I have came across one of these fittings, it has a single rose with nine separate 0.5mm flexes, max 40w lamp. Just wondered what the correct way is to connect all the cables together. I wasn't comfortable connecting all nine lives and nine neutrals together in a single connector block( due to heat off 360w ), so I connected all nine flexes separately in nine connector blocks and looped the incoming neutral and lives. I have been asked to install more in the property, but it is difficult to fit 18 connector blocks in the rose. Ps a junction box cannot be installed as concrete ceiling.
you should not get heat at the rose. the only place you'll get heat is at the lamp holders.
Upvote 0
I'll be honest, that anyone who thinks ramming that amount of connectors no matter what type they are into that rose is a good idea.
Upvote 0
View attachment 33794 Hi.
I really dig that light!
Upvote 0
had similiar one, took it home and dropped on a bench, soldered the lot leaving a length of 1.5mm wire for connection. insulated with heatshrink and rubber tape. load it up with led bulbs they will be around 5 watt each...
Upvote 0
may be a good idea to DIY one from a big wagobox, some brass pendants and rubber silicone flex. that may go well in those trendy new hip places, lots of light and easy to install too.
Upvote 0
Thanks for all of your replies, I like the idea of soldering, open to more ideas. This is like an IKEA special, which I expected to be already pre joined.
Upvote 0
