Discuss Straight wired and crosswired Ethernet connection? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Evening everyone..
I have just been experimenting with a cat5 wall plate on one end of the cat5 cable and an RJ45 on the other end.
The RJ45 connects to my router and the wallplate is situated in the office. I then connect a standard Ethernet cable (RJ45 on both ends) from the wall plate to the computer.
First of all I wired my cat5 cable as 'straight wired', ie both ends as T568A, it worked fine. I then thought I'd try it 'crosswired' and changed the wall plate to T568B keeping the RJ45 as T568A, it still worked. Why do they both work? Does it matter which way you wire it if they both work?
Cheers.
As long it is wired the same way at both ends they will work as a network cable, the issue comes when they are used to connect computer to computer rather than computer to network.
Most modern devices are auto-uplink, i.e. they detect which pair is which when they see the far end, and adjust themselves to suit. That way, either type of cable will work with any pair of devices.
This was not always the case - older devices did not have the capability to swich pairs so the correct cable was necessary according to what was being connected.
100BASE-T uses orange and green pairs only, being the ones that are crossed in a crossover cable. As HHD states this is equivalent to TIA 568A at one end and B at the other. 1000BASE-T uses all four pairs, but all 1000BASE-T hardware is auto-uplink equipped.
Reply to Straight wired and crosswired Ethernet connection? in the UK Electrical Forum area at ElectriciansForums.net
I am wiring a garden room which will be a home office, customer wants wired ethernet points and wifi down there from the house router Its too far...
I have had my kitchen rewired ready for a new kitchen. I was originally going to have a gas cooker so a 3 pin 13a socket was left on the end of...
htps://we.tl/t-JHXw09romZ quick share to photo Hi there. I am trying to convert previous cable network cat5e installed when had non fibre in 2015...
Hi all I’m after a bit of advice regarding wifi/secondary router. Data is not a strong point of mine so any advice would be very much...
Dear All. I need to wire an RJ45 socket and at the other end a plug to go into an Ethernet switch. Do I wire both ends as ‘B’ or is it ‘A’at one...
