Discuss Strange Voltage reading!! in the Australia area at ElectriciansForums.net
scotteng
Whilst testing a light fitting, i found a strange voltage reading from the switched live. When the switch is on, 240v 50 htz, all good, when the switch is off the switched live shows 79v 50 Htz. Taken the wire out of the switch, and still the same, checked insulation resistance and all ok.....and suggestions to why im getting these readings?
thanks
thanks for the reply chris,
Sorry to sound dumb, im still learning....what could could be causing this? is it a major concern? and how should i fix it?
thankyou
Sounds like a neutral has popped out IMO.
I had something similar recently, wired a radial socket circuit and had 60v at the end of the circuit, turned out a neutral had popped out in one of the sockets.
Reply to Strange Voltage reading!! in the Australia area at ElectriciansForums.net
Hi everyone, When checking my consumer unit voltages with the full board off, I stumbled across something head scratching. Measuring the feed...
Having a challenge understanding the concept behind why when you measure across line and neutral (live circuit) using voltage indicators we have...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
So, I was messing around yesterday with some old testers I have laying around to see if they still work I found my dads old Robin MFT and noticed...
