T
The Ghost
That is weird, the LED wont switch off??? A switch is a switch aint it??? Puzzled! I've put lux switches with LED no probs.
We've always used the 100w ones so a larger load, maybe that's why they work with the photocell, you would need confirmation on the 40w ones.
Try this maybe worth giving them a call/email to put mind at rest. Any good wholesaler should be able to get them. I have fitted a corn type LED lamp before after taking out gear what you have to watch is lumen output.got a job on, a park homes. 9 street lights with obsolete SONs. several failed, either lamps or control gear, and can't get replacements, so decided to go for LED alternative. can fit a E27 base and sourced 40watt LED lamps to fit. problem is that these lamps are not compatible with photocell switching according to supplier's research. anyone know of a solution?
