Hi. I have a small new build sit to price up. The consumer units are to be sited in the middle of the house behind the front door. After best way to supply from external meter box. I was thinking of using split concentric from kmf with a metal plate over it on internal walls. surface mounting or trunking not an option.
I think this is a -----up between the convenience / size of a KMF with the PITA factor of having to add your own mechanical protection, versus a larger switched fuse and the convenience of SWA?
It would be nice if there was a larger shroud for a KMF that was big enough to terminate SWA within.
EDIT Oh wow the word T0SS is blocked....
