Discuss sub main to consumer unit on new builds in the UK Electrical Forum area at ElectriciansForums.net
Hi. I have a small new build sit to price up. The consumer units are to be sited in the middle of the house behind the front door. After best way to supply from external meter box. I was thinking of using split concentric from kmf with a metal plate over it on internal walls. surface mounting or trunking not an option.
I think this is a -----up between the convenience / size of a KMF with the PITA factor of having to add your own mechanical protection, versus a larger switched fuse and the convenience of SWA?
It would be nice if there was a larger shroud for a KMF that was big enough to terminate SWA within.
EDIT Oh wow the word T0SS is blocked....
Reply to sub main to consumer unit on new builds in the UK Electrical Forum area at ElectriciansForums.net
I have a doorbell I want to install. The issue is the 16v transformer is designed to sit on a DIN rail. I have a 10 way 17th edition BG Nexus...
Hi All, looking for some assistance on this as finding different information wherever i look. We have a garage external to the house, which we...
4K
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
