T
timo
Afternoon All,
I've got a little project coming up soon and would like your thoughts to how i plan on running main sub feeds to some outbuildings etc. I have put together a little pic of the layout.
Here is what we have
Main House has a 3 Phase incomer with TN-S Earthing
Phase 1 = 2x 15 Way C.U's
Phase 2 = 1 6 Way C.U to house
Phase 3 = 2 redundant 60A switch fuses.
We have 5 out buildings to supply
WorkShop 80M away
A Large shed around 10M away from the Workshop
A Green house around 30-40m away from the workshop
A Garage 10m away from the main incomer
A pond & summer house around 30 - 40m away from the main garage.
Done some calcs and sized some of the main cables up already still some to do.
Thought i would put Garage on with small C.U and then the Workshop on its own (63A BS88) Switch Fuse
What's your thoughts so far?
Thanks for your time. :)
I think your plans are spot on, But without knowing the place its difficult to balance the phases, I'm assuming if the workshop and other buildings are all for private use so only used occasionally, it might be worth putting a nice 3 phase db in the house and feeding all the outbuildings on 63A MCBs. That way you could balance the loads in the house if this is what is used in normal circumstances. If all the house is on 1 phase and the other buildings are hardly used especially at night, then the balancing will be well out - Only as thought, suppose it depends on how often the other buildings are used!
Forgot to add - maybe worth taking 4 -core to workshop and taking 3 -phase over, always nice in a proper workshop!
Thanks Somersetsparks
Yeah i was thinking of making the 3 house cu's seperate on each of the phases and then adding the garage, workshop, etc on each on to balance the loads as much as poss. Its not going to be too much of a prob cos only 2 ppl live at this place so doubt big demands over all 3 or just one at anyone time will happen.
I've planned to take a 4 core over in case a 3phase supply is req in future at the workshop.
thanks again for your reply mate ;)
Sub mains info and advice -thoughts?
Australia
timo,
timo,
