Discuss supply to outbuilding in the Australia area at ElectriciansForums.net
Hi all,
just a few questions on a supply to outbuilding a friends asked me to do. I'm hoping to use this an one of my elecsa assessment jobs.
as you can see from attached pics is a 6mm 3 swa buried fed from a 20a mcb. rcd boards with 2x 20a radials and 1x 6a light circuits with 2x ncf's. now a lot of my work has been industrial so slowly moving into domestic.
friend positioned where he wanted socket outlets but they are quite high for my liking.
does the between 400-1200 apply to outbuildings? if so ill have to lower them.
im trying to make sure this job is bang on so thought id post to see what you think. I haven't
finished yet as you can see
cheers
I can't find any regs relating to it but I'm sure I was told somewhere that the 400 - 1200 rule doesn't apply to garages because you don't want them where they can damage or be damaged by a vehicle.
Hi all,
cheers
I'd be more concerned with the lack of discrimination than with the height of sockets.:)
Would the installation/reference method not allow a 32 A MCB for the supply?
i see your point. i have worded my description wrong i was planning on taking 2x radials from 1x 20a mcb and 1x lighting circuit from 1x 6a mcb, not good?
Reply to supply to outbuilding in the Australia area at ElectriciansForums.net
Last year we purchased a home that was built in the late 1990s It has one outbuilding, sort of a barn/shed about 160 feet from the house (and...
Hello. Just a lowly homeowner here who is beginning to panic after a major house renovation regarding relocation of the main supply cable to the...
  • Locked
5K
Hi, quick question before I start ripping a customers Consumer Board apart. Called out to a simple job of installing electric supply to a summer...
5K
