Discuss Tails from meter to DP isolator in the UK Electrical Forum area at ElectriciansForums.net
Trouble with clipped direct as soon as you enter an enclosure with it, unless you remove the outer sheath the rating goes down. Not at home with Regs to give an example.
Reply to Tails from meter to DP isolator in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
Hi we have been asked to run a 3 phase supply into a boiler house to feed a DB fed from next to the existing meter. Would we need to install Tails...
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
