Discuss Tails from meter to DP isolator in the UK Electrical Forum area at ElectriciansForums.net
Trouble with clipped direct as soon as you enter an enclosure with it, unless you remove the outer sheath the rating goes down. Not at home with Regs to give an example.
Reply to Tails from meter to DP isolator in the UK Electrical Forum area at ElectriciansForums.net
