- Reaction score
- 16,972
I expect you can get MCBs to fit that board? Maybe not rcbo’s though.
am I being suspicious thinking this is a joke?
Discuss Taken down wall lights, nothing else works in the Lighting Forum area at ElectriciansForums.net
I actually thought this was a wind up !!!! Are you a qualified spark?Hey guys I was asked if I could pop a couple of wall lights off and wago em up! Well.. for some reason no other lights work since doing this.. any ideas?
Attached some photos. Different angles of three different points.
Cheers guys!
The MEM carriers just pull out rather than being hinged at the bottom like the Hager ones.Main switch off then pull the carrier down from the top. If they are mis labelled it's not fun to try and remove the fuse under load.
So I'm told.
No mate I'm a little level 2 grad, just had a super daft moment. If I was qualified I could see why it would concern everyone haha... Don't worry I'm not doing any works! Just blowing myself up.I actually thought this was a wind up !!!! Are you a qualified spark?
I did wonder Ash as your Trainee tag has gone walkabout ?No mate I'm a little level 2 grad, just had a super daft moment. If I was qualified I could see why it would concern everyone haha... Don't worry I'm not doing any works! Just blowing myself up.
Hopefully when I finish level 3 I'll be wiser haha
Reply to Taken down wall lights, nothing else works in the Lighting Forum area at ElectriciansForums.net
