L
Lilyrose08
Hi All, When testing exposed metal work to establish whether it needs bonding you: You test from main earth disconnected from MET to exposed metal work insulation tester @ 500V what readings should you expect if it needs bonding ? Also when testing with a continuity test what readings should you expect then ?
