Discuss Testing Mains Heat Alarms? Small fire with no trigger! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Joe S
I have had an elderly customer who has recently had a small fire in her Kitchen from a pan. Her daughter has contacted me to ask why the alarms didn't go off. I have since been in contact with the manufacturer of the Alarms and their response was ' the button test is sufficient and no other method should used due to possible damage to the detector'. I had tested the alarms upon handover after a full rewire to find all alarms triggering as per normal. The issue I have is that I have now lost a little faith in the alarms as they didn't go off when needed. Anybody else have any issues similar to this?
Thanks alot
Joe
Thanks alot
Joe
Where were the heat alarms situated?
lots of fire and smoke produced on burning pan, but good ventilation and no much heat to be picked by the alarm...
give it bit of grilling with a heat gun to be sure.
I thought about using a heat gun but they have assured me not to. They have also recommended to not use artificial smoke spray for the other alarms and that button tests are ok for them aswell?!
This is what they emailed me today:
A0EE71F1-2EC2-4893-A889-0D1BFF122061@home
I've always considered Aico a quality make and have always used them, but this is food for thought.
I can't see an attachment joe for the email.
I can't seem to get the attachment on here for love nor money. I've tried copy and paste, loading it into photo bucket and even screen dumping my phone as a picture but it can't see the image???
The Aico meet all relevant standards.....but like any fire, smoke and heat never act the same.
Testing any detector by button alone does not help..then need to be checked correctly by an approved kit such as Solo, using smoke cans, and hot air testers.
With Acio, the heat detector will not activate until 58 degs C which is quite high for a heat detector, most Pro are set at 50 degs.
Air circulation, rate of heat, drafts and positioning can all have issues on how quick a detector will respond.
Now a burning pan, is not going to instantly heat a kitchen to 58 degs, it will take time, And i would expect a heat detector to take at least 10 to 15mins @ 2m to pick this up, please remember at this this time it is confined fire in a pan ...not a spreading fire, so heat is confined to on place only. If the heat was below 58 deg, but smoke was being produce at high level, then any optical detector within a circulation area eg hallway would have activated.
I agree with you Taz but the fact that Aico say don't test with anything other than the button has got me worried now. What other alarms are available that allow testing with button and secondary items such as smoke/ heat?
Reply to Testing Mains Heat Alarms? Small fire with no trigger! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
I currently have a home with 7 interconnected, hard-wired smoke detectors. I have a hard-wired heat alarm in the garage that I need to have...
I'm about to start first fixing this fire alarm in the industrial unit we are wiring, at the moment its totally empty and eventually will have a...
Can someone please guide me on this? I have virtually no experience of home alarm systems. The client has an alarm which had been fitted to her...
