Discuss Testing Zs for Three Phase Motor in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
DanBrown
I have been pushed all of a sudden towards testing my work off myself and only being an apprentice myself and not done my Level 3 testing yet, i was just wondering how you do:
An earth loop test - Zs on a three phase motor.
The motor is speed controlled - so im guessing i need to wire-out my controller beforehand..
Dan you wouldnt do Zs on a motor.
you would do Zs on the circuit up to the starter/controller, and then do R1+R2 on the circuit after the starter, if required, and add this to the Zs
Reply to Testing Zs for Three Phase Motor in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Good day to you. I need electrical drawings urgently and hopefully there is someone that can assist me. They are all for electrical trade test...
Hi gentlemen, I have three phase motor has an issue. This motor is star connection. When I just disconnect the power cable coming from MCC...
Hello, I am hoping this is in the correct forum. To start, I acquired a film processing machine that runs on 3 phase. Now before getting the...
I posted a month ago regarding a single phase motor + panel I have been given to try and sort following water damage to the panel. The assembly...
