Discuss Thermostat in the Australia area at ElectriciansForums.net
F
fire
a thermosatat is supposed to work as a switch and open and close as the temparature changes, so why does it need a neutral?
can anyone help.
If you connect a live and a neutral across the contact of a thermostat then stand well back when you switch on because it's going to blow it to pieces.
Just because a wire is black it doesn't necessarily mean it's a neutral. Someone could have used the black wire of the cable as a switched live but they ought to have sleeved or taped it as a different colour to indicate this.
think he means some of the newer stats. which are electronic and need a supply rather than just the old bimetal switch, which is just L and S/L
the thermostat that i bougth from screwfix has the manufactures instruction in it and says that the neutral must be connected.
Thanks for clarifying, we call those things energy regulators or simmerstats in this neck of the woods.
The neutral is to work a small heating element inside the thermostat. The heater makes the thermostat more sensitive to temperature changes in the ambient air, thus making for more accurate temperature control of the room.
Some of these 3 wire thermostats will work without the neutral connected, but not quite so fast or accurately.
Reply to Thermostat in the Australia area at ElectriciansForums.net
m having a bit of an issue that is proving difficult to resolve. For 2 years I have been having no problems with my setup. I have a 3 zone house...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hello, I'm trying to upgrade my mechanical thermostat to a wireless one but when I connect the wires it doesn't work. This is the old one: And...
Hi, i’ve been trying to buy a smart switch 1 gang 1 way but i opened my conventional wall switch and i only have 1 red wire(Live Old UK) 1 black...
