O
Old Tiler 4029
I've installed like this before a few times in the past, they were just standard metal clad skt's. Is it not good practice ?
Standard sockets but its not a problem they are 25ft up in the perlings i like to see the cleaner try use themAre they standard socket outlets? the reason I ask is that if they are non standard ie pins turned 90 degrees etc only the lighting could be plugged in.
Protection by 30mA RCD not required for socket outlets under the control of skilled or instructed persons.
