Discuss to rcd or not rcd?? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
E
egginyourface
doing a small job in a school , we're upgrading lighting and extending some circuits, we might also be running some new circuits.
the customer has asked for a periodic inspection. now the question i have is, after the inspection and remedial work is completed can we leave the old circuits with no RCD and say the installation is satisfactory and complies with bs7671
my main concern is the sockets as children have access to them, ie computers. light switches and fitttings are out of reach.
am i right in saying everything must b rcd protected to comply with latest regs
Not always.
Socket outlets should be RCD protected, but thats not always the case, especially if the cables are surface run and a number of other things are taken into account.
depends also on the work you are doing. all your new work has to be to 17th. existing circuits, not touched by you can be left as are, but if non-compliant, should be noted
Reply to to rcd or not rcd?? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all. I have a small question about inspection interval labels. We all know to fit one of these labels with the relevant date upon completion of...
Hello! I've been racking my brain this evening about some RCD selections. I've been doing some work for a solar installer, and they've asked me...
Hi Guys, Long time member and not a regular user here. I do pop in here when the odd unknown pop's up and unable to locate an electrical dilemma...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
Hi all, After some options/opinions on fault finding N/E fault on ring final as fairly newish to being out alone. Customer wants to upgrade from...
