Discuss Tool for 45 and 90 Degree Cuts on PVC Trunking in the Electrical Tools and Products area at ElectriciansForums.net
RDB85
Trainee
I have bought a Mini Mitre Block for some Trunking as the cutters I have are better for Mini Trunking. I’m just looking for something that will allow me to mark the angle before cutting it. I was thinking either a Tri-Square or Trend ANGLEFIX. I then also need some advice on a file to smooth the edges down.
Any advice would be great.
That’s the problem some of the comments say they are fine. Others not so much.
If you are doing ultra fine woodwork then you'll probably notice if a square is fractionally out.
If you're chopping some plastic trunking, I wouldn't sweat it too much. Your technique with the saw will have a bigger impact on the final result than your set square being a quarter of a degree out.
Pick something reasonably priced from a brand you know and you'll be good to go. Don't overthink it.
years ago, my dad wanted a mitre block. he made one from some scrap timber, similar to this:
If I had a job that required a lot of trunking to be cut then I might be tempted to buy a cheap chop saw...
https://www.NoLinkingToThis/p/titan...=4583451660521506&utm_content=S - Power Tools
But for a one off cut then a cheapo hacksaw and mitre box is fine
That does look okay to be honest. I am looking to buy this one:
https://www.NoLinkingToThis/p/evolu...lti-material-sliding-mitre-saw-220-240v/2965v
Reply to Tool for 45 and 90 Degree Cuts on PVC Trunking in the Electrical Tools and Products area at ElectriciansForums.net
I’m doing a large install with PVC Trunking I had a Magnusson Mitre block but it’s not that great with a large hacksaw. Does anyone have any...
5K
is there such a thing as a pre made bend for MT1 or MT2 size mini trunking at 45 degrees? I want to change around my living room but I’ll have to...
Hi everyone, I need some advice about how to chase into engineering brick. Full story below. I've mounted a TV onto the wall, not my preference...
8K
Hi all, Was just looking for some best practices around using plastic mini trunking. How do you guys join trunking on corners of walls that are...
28K
Squid
S
