RDB85
Trainee
Nov 23, 2017
1,088
178
638
Liverpool
Trainee Electrician
I have bought a Mini Mitre Block for some Trunking as the cutters I have are better for Mini Trunking. I’m just looking for something that will allow me to mark the angle before cutting it. I was thinking either a Tri-Square or Trend ANGLEFIX. I then also need some advice on a file to smooth the edges down.
Any advice would be great.
I actually use a chop saw, cowboy that I am. A cheap screwfix one is fine and just get a finer toothed blade for it. I’m expecting abuse for admitting this but it works for me!
I would love one. Just out of my budget unfortunately.
Plastic trunking is best 'filed' with the edge of a knife
Oh right. I don’t think I would trust myself, hence why I was asking about a file.
Mitre box or chop saw for me.
Reactions: Jim_e_Jib and RDB85
Back of an old hacksaw blade would do just as well.
Thanks I will give that a try. Any mitre box recommendations before I order a cheap one and regret it.
A square is a square, provided it's actually square, and will give you 90 or 45 degree angles.
That’s the problem some of the comments say they are fine. Others not so much.
If you are doing ultra fine woodwork then you'll probably notice if a square is fractionally out.
If you're chopping some plastic trunking, I wouldn't sweat it too much. Your technique with the saw will have a bigger impact on the final result than your set square being a quarter of a degree out.
Pick something reasonably priced from a brand you know and you'll be good to go. Don't overthink it.
years ago, my dad wanted a mitre block. he made one from some scrap timber, similar to this:
If I had a job that required a lot of trunking to be cut then I might be tempted to buy a cheap chop saw...
But for a one off cut then a cheapo hacksaw and mitre box is fine
Reactions: RDB85
That does look okay to be honest. I am looking to buy this one:
RDB85
Trainee
Liverpool
Trainee Electrician
Tool for 45 and 90 Degree Cuts on PVC Trunking
Electrical Tools and Products
RDB85,
Mike Johnson,
