This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
R
Rikki Barrett
Been called out to a job where they have recently had underfloor heating installed.
Firstly, they have put the sensor close to a central heating pipe so its too hot to switch on.
I got the customer to leave the central heating off the following day and the temperature the sensor is picking up dropped to a point that I could get the programmable stat to activate.
Now when it kicks in, it stays on for about 10 seconds and then trips the mcb. Its a 6 amp breaker and should be ample for the size of underfloor heating it serves.
I didnt have my testers with me, never tested any underfloor systems, would there be any problems with an IR test to the underfloor mat? Im pretty sure there is a fault down there, it only trips when the stat turns on.
Any thoughts would be grateful. Cheers.
Can IR test between L & E no problem, there will be a resistance (you could work out what to expect using ohms law) between L & N, resistance is a function of the heater cable length.
In theory the cable should have been tested before install, after install (before tiling) and then again on completion, so someone hasn't been doing their job properly.
Basically I have been trying to get in with a builder who gets some nice big jobs.
This job is one that was finished about five months ago, its a big top notch job and there has been some 'snags', he has been mucked about by as many as five electricians.
I have done a few other jobs with him and I hate being the bearer of bad news, hes gotta get the floor up I think. He says he knows where the sensor is and can get to it, that needs to be moved definitely, im just trying to think why when the stat kicks in, its overloading at the board.
Im gonna test it next week.
If they've used decent adhesive that'll be new tiles and a new underfloor heating grid. :(
Sounds like the mat has been damaged by the tilers. As already said you normally have resistance readings taken before during and after the install so it's obvious if the mat has been damaged.
hi
the situation with the thermostat has happened to me before, after many visits to site we eventually came to the conclusion that the sensor must have been moved therefore touching the mat giving false readings(bloody tilers!)...... what we did was fit a standard room stat and it works a treat.
regards
gary
